So I happen to be a happy new boat owner. Got 22' boat with 2002 VP 5.0 GL-B with 260hr. Boat wasn't in use for almost 2 years and had hard time to start up. so I decided to do a full tuneup. Changed spark plugs, distributor cab, rebuild carburetor, changed all oils. Distributor arm was stuck so I had to remove distributor to cut old plastic arm and insert new arm. Reset timing using "out of sink" procedure from VP workshop manual and... engine does not want to start. When I insert distributor back, it only goes in 2 positions. one position is somewhere over cylinder 1 cable (you fine tune distributor so it's aligned) and do time advance once engine is running, but it cranks, but nothing happens. Checked spark (using sync flash tool) and it's ok. is there something Im doing wrong? carburetor has fuel. If I manually press accelerator pump, I can see fuel shoots inside. Any help is appreciated. Thanks.
