Volvo Penta 5.0 GL Starting Problem
01Danes01
I have a rebuilt 2004 Volvo Penta 5.0 GL and I took it out of storage to get it running and it won't start. When I turn the ignition, I hear a relay kick in but the engine does not turn over. I bought a new battery thinking the battery was dead. Even with the new battery, the engine is acting the same. I checked the voltages at the starter and I'm getting 6 VDC no matter if the ignition is on or off. I tried shorting the Positive and Negative together on the starter but, this didn't do anything except turn the dash lights on. Any ideas?
StingrayMike
1st off, sounds like you are missing 1/2 your voltage, you should be seeing 12v.
check all your cconnections, especially the grounds.
