Augoose
- Mar 21, 2010
- 1,223
All,
my 1999 VP 5.0GL is experiencing an occasional stumble at take off. Almost sounds like one of the cylinders not firing. If I continue to hold the throttle position, it will continue to stumble. If I increase throttle, it seems to work its way through the stumble but takes up to 20-30 seconds. If I back down to idle and then apply the throttle again, it runs perfectly. Idle is great, revs out of gear fine, and 9 times out of 10, it has a great hole shot pulling skiers, etc. When it doesn't stumble, the boat appears to run fine all the way through the rpm range.
This stumble is what I believe caused a hydro lock a few weeks ago (written up in another thread). That time the engine died as the idle was set a bit too low.
Today I pulled a skier about 15 times. Only once it stumbled. When it stumbled, I backed down the throttle to idle and then immediately increased throttle again and brought the boat back to the trailer - ran fine the whole time back.
About 6-7 years ago (about 175 hours ago) I put on a new coil, new plugs, new dizzy, new spark plug cables, and I rebuilt the carb.
My plan is to inspect the dizzy, plugs, cables and coil for poor connections. I also suspect my alternator as well, possibly the feed to the fuel pump is having issues, but I wouldn't expect the boat to be able to immediately recover following a stumble if the fuel pump was having issues - if the pump failed and I ran the fuel bowl dry, I can't see it immediately recovering after letting off the throttle for just a second?
Everything points to electrical (at least in my head) but I can't point my finger at any one component at the moment because the symptoms are intermittent.
Thanks for the help!
