Hi All,
I'm winterizing my 1999 Doral 216cc with VP 5.7GS (SX drive). I installed a closed cooling system in 2004 when i started running the boat in the ocean. Usually, I get a marine shop to winterize but doing myself this year.
Planning to flush the raw water intake with antifreeze using muffs. Most advice says "run the engine for 5 min first to open the thermostat". My question is: With the closed cooling system, can I just start flushing anti freeze through the muffs immediately (without the 5 min warmup), since the thermo is on the closed side of the system?
Thanks in advance,
Mike
Thanks in advance,
Mike
