volvo penta 5.7 GSi water in all 8 cylinders
MJCLD
I have water in all 8 cylinders in my 1998 OMC Cobra/Volvo Penta 5.7 GSi engine. I had the boat out of the water and verified there was no blockage in the exhaust path. Anyone have this problem before? Any ideas on how to fix it?
MJCLD
Re: volvo penta 5.7 GSi water in all 8 cylinders
Clarifying information:
I have water in all 8 cylinders in my 1998 OMC Cobra/Volvo Penta 5.7 GSi engine. I had the boat pulled out of the water and cleared some barnacles from the exhaust passage in the propeller. We then verified there was no blockage in the exhaust path by hooking it up to the hose. Ran the boat for 30 minutes at idle and high speed. Engine stalled a couple of times while idling. Limped back to the dock. Pulled all 8 plugs and they were all dry. Reinstalled plugs and started engine several times. Someitimes it started easily and sometimes it cranked a lot before starting. Finally the enginewould not turn over. I pulled all 8 plugs and all of the cylinders had water in them. Anyone have this problem before? Any ideas on how to fix it?
bruceb58
How old are your exhaust manifolds/risers? Usually you would only have this happen to one side but it is possible both sides are leaking.
MJCLD
The engine, manifolds and risers are 2 years old. We pulled the risers after the first time we got water in the cylinders. The risers and the seals looked good.
bruceb58
You put new gaskets back on before you put it back together right?
MJCLD
We put new manifold to riser gaskets in when we reassembled the risers. There was no blow by or rust on the gasket surfaces.
LyleW
Could it all be coming from water in the gas tank?
MJCLD
I don't think the water is coming from the fuel tank. The water that came out of the cylinders had no trace of gas in it.
