1990 Volvo Penta believed to be a "500", does have Rochester 2 barrel (17059059) w/ new electric choke, and new vacuum pulloff. Has SP-A CD Trim outdrive. Carb has been overhauled to cure hard starting. Starts almost instantly when cold WITHOUT having to pump. The problem: after a long moderate speed run, engine will stall backing throttle down to either get into neutral or reverse. Am lead to believe this does NOT have a shift interrupter switch (if it does, where is it??). Any ideas as to what is causing the stall??
