Hello there. Recently purchased Carlson csx23 with 7.4l gsi vp engine and dpx duoprop drive. boat has 340hrs. Seems like boat goes into Slow down mode when cruizing on the lake.I am an auto mechanic so have knowlege how stuff works. So far i figured out that in order for the ecu to go into slow down mode there have to be 2 sensors out of spec (low oil press or high temperature). So i noticed that everytime i am cruizing and boat cuts off the throttle my temp gauage jumps to 250deg. then when i take gas lever down engine rpm goes down below 1200rpm the temp gauage goes back to 110deg. and boat has power back on, sometimes this happens one a day sometimes every 30seconds. Boat is for sure not overheating. It would look like there is wiring issue between temp sensor and ecu. I checked all wiring, even tried to wigggle wires around while having my dvom hooked up to see if there is broken wire somewhere inside, all wires look good. Next i replaced temp sensor with autozone sensor that fits 7.4 gm motor(sensors looked exactly the same) but no luck i think that it even got worse? bad sensor out of the box? or the issue is getting bigger, last night we were on the lake and it was the worse ever she was going into slow down mode everytime i wanted to go above 2500rmp. What do you guys think? Should i start looking for a new ecu or try to get another sensor from VP.? Also how can i read codes from it? Any feedback welcome. Thanks!
