Re: Volvo Penta 8.1 GSI Problems
Thanks, Rodbolt, Cyclops2 and Newport Dave. The vessel is a Doral 360 SE,2002. Volvo claim that they fitted the 7-inch high spacers between the manifold and riser, because of "pressure" issues. An inspection of the valves show that they arent perfectly <br />in sync. Both engines have taken water into the inside banks in the central cyclinders. The vessel was stationary at the time of failure and had just had the engines run at low RPM simply to ensure running condition following a two month lay over at the dock.
