I have an AQ 120b and I need the torque specs for the valve cover
S scsjessek Recruit Joined Feb 19, 2015 Messages 1 Feb 19, 2015 #1 I have an AQ 120b and I need the torque specs for the valve cover
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,240 Feb 20, 2015 #2 Hi there, welcome to iboats! Well the service manual doesn't spec out any valve cover torques for your engine. Looking at your engine model parts diagram it looks like you should have 10 studs that utilize cap nuts and spring washers holding the cover down...Correct? Item numbers 23, 27 & 28 http://www.volvopentastore.com/Cylin...view_id.784403 If you're using an actual torque wrench, I wouldn't go much past 150 inch pound force which = 12.5 foot pounds.
