- Jul 23, 2011
- 50,614
Volvo casting 854031 as used on the 290, 280, DPA, etc is a known weak link on the AQ series drives
try as I might, I never had one last more than 3 years and that is even with epoxy coating the new ones.
they just dissolve in brine and last about 5 years in fresh water.
so I think I found a permanent fix for mine
The old one has 40 hours of run time or about 15 months and was pulled last January when I pulled the motor. you can see the pitting starting in a bunch of locations and the casting has a bunch of oxidation blisters under the remaining paint. the epoxy paint was POR15 with the POR15 hardnose paint.
the new one is 316L stainless, laser cut, tig welded and tonight I will hit the interior edges with the die grinder and clean up the exterior.
something else may corrode on the drive now, however this wont be it.
would have machined a billet unit, however the laser and tig were much faster.
