Volvophile
- Jan 25, 2005
- 11
Just bought this boat and still flushing all the gremlins out of the bilge
<br />Got a quick question about the raw water pump on my 68 aq120. (Same as aq110 but with dual SDs).<br />I replace the chunk of carbon in the pump with a new impeller and it seems to move water OK, but drains a lot out of the weep holes, almost enough to keep the bilge pump going.<br />Is this normal for these pumps, or is there a shaft seal that is bad to.<br />Or is the impeller supposed to seal water from the shaft since I cant seem to find a part number for a seperate shaft seal.<br />Thanks
