markmilkamp841
- May 23, 2013
- 3
Hello everyone I am new here but could really use the help with my 83 Bayliner Capri with a Volvo Penta 125a. I had it professionally winterized last fall and topped it off with four gallons of fresh fuel this spring when trying to get it started. The engine cranks over fine and will run a bit if I pour a cup of gas in the carb with some starting fluid. I am pretty sure it was an issue with a bad fuel pump. I picked up a used on at a dealer that I was told works and still no dice. I took the intake off the fuel pump and sucked the line from the tank--it flowed well. Needless to say I did not kiss my wife that night
I also unhooked the outlet that screws into the carb and turned it over. No fuel comes out the outline from the pump. I then took the pump off, put some gas in the intake to fill the chamber and manually rocked the arm that sits on the shaft, while plugging up the loose holes--no fuel comes out the end. Is it safe to say the used pump I bought is shot? I hope its not a dumb question I am by no means a expert here. There is no filter in the fuel system just tank, pump, and carb. Am I missing anything else in the fuel system of any other reason why Im not getting fuel to the carb. When I cleaned the used pump out I did notice a healthy amount of black junk and debris come out,
but air blows though. Any help here would be great.
Thanks
Mark
Thanks
Mark
