Volvo penta aq131d power tilt not working
TrevorStott
As I'm putting the boat back together I'm finding issues. Right now the power tilt isn't working. When I hit the switch I hear a click back there but no motor or movement. Fuses look fine. Wiring looks fine. No loose wires disconnected. Worked in the fall when we were putting it away. Any ideas on what to check?
TrevorStott
Battery is good, motor turns over without issue and I checked the fuse.
kenny nunez
A good chance that one of the relays under the plastic cover is in need of replacement. Also if the cover is off be sure that the limit switch on the top of the tilt unit is connected and seated.
TrevorStott
Is there a diagram or picture somewhere I can refer to? I did get the stern drive up by hot wiring the motor and the stern drive indicator light recognizes that it's up which is good i guess. Can't use it this way though.
QBhoy
Change over the relays and see if it does the opposite.
TrevorStott
I took the cover off and it looks pretty complex in there. I can't easily identify a relay, looks like just a bunch of wires. I may have to take it to someone. This is beyond me.
dennis461
Yes, it's a tight fit in there. Do you have the black contoured box?
TrevorStott
Here's some pictures of the top electrical. As I said the motor is fine and I can hot wire it up and down but that's rather complicated to do when you need to.
dennis461
Two relays and a limit switch in there. The relays are upside down, the wires slip onto the terminals. I would make sure all external connections are good first. Including the console switch for up-down. I need to find my old relay info, these are slightly smaller than the ones found in automobiles.
Go to this thread, my post #18 shows what I used in the past.
https://forums.iboats.com/forum/eng...do-totally-dead-messing-with-tilt-relay/page2
TrevorStott
So if I just get 2 new relays I should be good? I went back and can see how they pull out. The wires all look solid. I have no up or down so switching them won't help. I just hear a click with no further action or noise.
TrevorStott
Here are some more pictures, I pulled what I believe are the relays out. They look hardwired and in good condition. Not sure if that matters or not.
TrevorStott
Okay, now I see the real relays and stop limit. They don't seem to come out but I'll do some testing this afternoon as well
TrevorStott
Ok . I wouldn't have found this on my own but with a friend that knows a little more than I do about relays stopped in and we were able to determine that both relays are good as well as the stop limit was also good.
Further testing revealed that we were only getting 8v at the relays. Battery was 12v, but started tracing back. Found that the 40a fuse was where it started. Sanded the ends on the fuse holder lightly and voila 12v all the way through and the power tilt now works as expected.
Thanks, hope this helps others.
