You don't have a gimbal bearing, they didn't show up till 94 for Volvo.
If you go to the link before, find your engine and look at connecting components for your setup.
well the part that is between the outdrive and motor bearings went out and the housing that holds bearing is what i need plus inner and outer bearing,not sure what it is called and not sure where to find number like aq200 or whatever it is!!!thanks for your help
