Volvo Penta DP-e Outdrive Seals
Bancs
I need to replace the seals on both inner and outer shafts. My service manual has a part listed (885192-4) which is very expensive. Do I need this tool to complete the seal replacement?
muc
"Retired" Association of Marine Technicians...
No. That tool is to help remove and install the drive from the transom plate.
Bancs
Need assistance with another issue. Part number 853871 (sealing rings) for the inner shaft was replaced by part numbers 553807 and 553808. The service manual doesn't indicate which part goes on the shaft first. The old parts were identical but the new ones are different. Any help with this is very much appreciated. Thanks.
