Volvo penta DP out drive
AZ boat
Does anyone know what out drive this is?
On a 1993 chaparral sunesta deck boat with a 5.7 liter GM motor. That says 572 on the engine cover.
I need parts for the motor and out drive specifically the trim cylinders.
Please help
Augoose
No Title
Can you find the serial number stamped on a plate on the port side of the outdrive?
I attached a VP drive chart pdf as a reference as well as a photo of the same chart - I can't delete the photo and its too small to see anything so don't bother with that....
If you can find the serial number you can then use the Volvo penta store to look up parts.
  • Volvo Drive Chart 1.pdf
