Hi all,
I was running my engine (454) at idle in neutral, boat on the trailer, ear muffs attached, when the engine suddenly stopped. Engine was locked up.
To cut a long story short, I found the problem was in the drive. Removed the drive, separated the lower and upper units. Lower unit seems to be ok, upper unit was locked up. As of now the upper unit will only rotate counter clockwise (viewed from the front of the engine) the engine rotates clockwise. I was having difficulty shifting in and out of gear at times while under power prior to this incident. I would appreciate any advice.
Thanks.
Thanks.
