First a little history. 1996 Glastron 21.5 Anniversary Special Bowrider.
Ran boat with bad impeller. It overheated to the point where I could smell paint burning (or something else). Engine shutdown (built-in protection). Had impeller replaced. Ran boat and noticed engine noise like a rocker arm or valve noise. Had valves tightened. Timing reset. Boat runs fine except when throttled full for a hole shot I get noises from the engine which sound something like noisy valves or engine knock. This is only noticeable with hard throttling. Easy gradual throttling does not produce the sound. Mechanic thinks it is low octane gas or detonation problem. Never had this problem befrore as boat runs fine on regular gas. Any ideas? Is it okay to run the engine anyway? Thanks for your help.
