1988 Three Bouys houseboat, AQ151C Volvo Penta 4cyl. Was tying up dash wiring harness and noticed the guage cluster pegging at low end as I moved the wiring.
After a little digging, I found what appears to be a diode located in the purple wire from the switch to the voltmeter. I determined that this was where the fault was. When touching the diode, slight movement causes the gauges to peg to the low side.
I have seen no reference to a diode at this location on any wiring diagram or manual. I figure it was installed by a previous owner, but no idea why it would be needed. All other dash wiring appears to be original and untouched.
My question is, can I just remove the diode or may there be a purpose for it. If it's needed, I'll have to replace it since it appears to be shorted or faulty.
Thanks so much for any thoughts...
