Volvo Penta gimbal, u-joint and bellows replacement
twaterski
I have a '95 3.0 GS Volvo Penta with an SX outdrive. When I purchased the boat, I recognized a solid "thunk!" when putting the boat in forward or reverse and negotiated a decent price realizing there would be some repair costs. Just after the purchase, I found that the frond engine mount lag bolts were stripped out. After some fiberglass, resin, redrill and longer lags, that problem is fixed.
Still the "thunk!" when shifting. Last fall, I pulled the outdrive and found the gimball had a lot of fore-aft slop. Also, the u-joint was sloppy, and wet. When I purchased the boat, there was no water in the bilge. Throughout the summer, I noticed more and more bilge water.
So, for this spring, my project will be to replace the u-joint and gimball. I am also considering replacing the bellows, shift cable, and engine coupler. I have a repair manual, need an alignment tool and slide hammer.
This should be a fun project, a learning project. Any lessons learned would be helpful. I will keep you posted with updates.
:eek:
Don S
Re: Volvo Penta gimbal, u-joint and bellows replacement
You say "Gimbal" a couple different times, but it sounds like you are talking about two different things. Basically, there is no such thing as a Gimbal back there, you have a gimbal bearing, a gimbal ring, and some call the transom shield a gimbal housing.
So what has back and forth slop and what are you replacing?
attachment.php
twaterski
attachment.php
My apoligies for lack of clarity. The gimbal bearing is sloppy.
jerryjerry05
Alignment tool,e-bay.
Slide hammer.GET A GOOOOD ONE.
A cheapo might work but Snap-on or Mac tools have the good stuff.
Even then it can be a bugger.
Pics always help.
TregoMark
I replaced my gimbal bearing and u-joints last spring in my 2000 3.0 GS. To remove the gimbal bearing, I rented/bought a slide hammer from my local auto parts store. Took about three knocks and it was out. I then installed the new bearing using a very large socket. My new bearing was sealed, so I didn't have to line up the grease hole.
I removed the pinion bearing carrier from the outdrive and then the u-joint was separated from the pinion bearing carrier. I replaced the seals on the carrier because they were worn and letting water into the outdrive. I then took the new volvo u-joint (man that was pricy) back to the shop where I bought it and had them install the u-joint onto the pinion bearing carrier. It seemed like a tricky job and I figured I'd have someone with experience install it. They also aligned my gimbal bearing in about 5 seconds which would have taken me hours of frustrated cursing. They did those two things for $20 because I bought the parts from them. I figured it was the best $20 I've spent in a while.
I then installed the pinion bearing carrier/u-joint into the outdrive (with the new gaskets) and bolted on the outdrive after greasing the u-joint splines. New bellows were installed and everything torqued down. I saved money by doing most of the work myself, but I would recommend having a trusted shop install the u-joint to the carrier and do the alignment.
