Volvo-Penta Heat Exchange
Dave591
Dose anyone know where I can get a used Volvo-Penta Heat Exchange for a A125a
jerryjerry05
Re: Volvo-Penta Heat Exchange
I know Volvo parts are expensive.
But you sure you want to put used parts in the cooling system?
You tried flushing or taking it to a radiator shop for an acid dip?
The link Raven posted is for a tested unit: it's tested for leaks not flow.
What's the motor doing that you think the exchanger needs to be replaced?
I've found the manifolds the biggest problem for the 125/131
Fill out the profile,location.
You might be close to someone who can help.
Dave591
THE exchanger inside has a hole in it thanks
take it to a good radiator place, they can repair it for a few$.
If you want new, there are many will-fit heat exchanger manufacturers out there.
Dave591
how do you get the core out of the exchanger
jerryjerry05
The exchanger is held in place with pressure and a o-ring.
The bottom is pushed in place and sealed with the o-ring.
Take the cover off, then remove the screws on the bottom of the housing.
Then just push/pull the insert.
Walt T
You can have radiator shops build you a brand new one. Done that many many times, have also had that done for heater cores in ambulance bodies.
snobdr
I have one sitting around. I took it apart to make sure the internals were ok so it will need gaskets to put back together. Pm me if interested
jerryjerry05
This site doesn't carry any hard parts.
That's a dealer part.Cobe Marine in Pasadena,Md.
Cobe is a Volvo dealer.
Good parts dept.
