dabbenante
- Aug 14, 2010
- 13
2001 Larson Boat with Volvo Penta 5.0 GLPEFS - Inboard/Outboard. Carburetor
Water was leaking within engine hull area. Brought to dealer and he said circulating pump was bad and replaced. Water was leaking following week and enging running rough at idle and limited power. Found that seawater pump had bad seal and replaced seawater pump. (Realize now that dealer probably replaced wrong pump). Took for a ride this past weekend and no water leaking but started hearing an intermittent chirping alarm (temp gauge was fine) and engine was running rough (suddenly not able to get above 2500 rpms) and oil pressure gauge was reading low oil pressure when at low rpms. Limped back in and brought back to dealer.
Dealer said he thought water line through transom was bad and needed to take out of the water to fix. Called today and said that he removed the thermostat housing and that there is a hole in the intake manifold right by the hot water sensor. The hole is actually on the screw casing of the heat sensor located on the intake manifold. It looks as if it was broken when someone put something like a screw driver in between the thermostat housing and the manifold to pop of the thermostat housing but I could be wrong.
So, I can purchase a new intake manifold for $800 plus the cost to install or I can take the boat back home, pull the manifold and have my brother-in-law that runs a machine shop try to do some welding magic. The dealer is not sure that the "hole" in the manifold was the cause of my problems but cannot test anything else until it is fixed. He says both the oil and hot water sensors are bad. I am thinking the thermostat was bad or clogged the whole time and kick myself for not doing it myself.
Any advice on how to handle the exhaust manifold repair or replacement.
Thanks
Thanks
