Re: Volvo Penta Outdrive makes grinding.........
Drain the drive lube into a pan and inspect the lube oil and magnet on the drain plug for metal fragments. If you see metal bits/chuncks and the lube smells burnt you will need to remove the drive for disassembly and inspection.
