Volvo Penta Outdrive rebuild or swap??
Kabbes6
Have a buddy with a 97 Fourwinns bowrider. Has a 3.0L Mercruiser motor with a Volvo Penta SX Cobra outdrive. He says the outdrive blew the top end and screwed up the bottom end as well needs a full rebuild. I know nothing about boats. Have rebuild lots of motors but never got into boats. Would it be better to rebuild the outsdrive or swap it out for one?? Looking at the price of used working volvo outdrives of 5 grand seems like there is a better option. Wondering if you can put a Mercruiser outdrive on the boat?? There seems to be lots of them around. what all needs to be down to swap them out??
thanks,
if you swapped to a Mercruiser Drive, or even an SEI, you need to replace everything drive related and exhaust related. That is a fair amount of work
lack of maintenance is what most likely killed the drive
best bet is find a used drive in good condition.
Kabbes6
Thanks for the reply. We have found a loner boat same vintage and motor but with e mercruiser outdrive. Would that all bolt up or would it still be a lot of work??
briangcc
As Scott said, you're comparing apples and bananas. They're completely different animals.
Having had both now, I prefer Volvo - its much smoother shifting. Downside is, as you've found, the parts price is astronomical for anything Volvo.
What size boat? You might be better off finding a 4.3L donor and swap everything over. I've yet to hear anyone say I wish I had a smaller engine on their boat.
Kabbes6
Gotcha gotcha. Yeah i like the sounds of more power. Thanks for the info will keep looking around.
