Augoose
- Mar 21, 2010
- 1,223
I've read over all the threads talking about what gear oil to use, how the Mobilube SCH is not available here (nor is the Mobil Delvac Synthetic for that matter, or at least I can't find it locally) and how any GL-5 synthetic is good enough as long as it doesn't contain the additives for limited slip differentials.
So, I'm trying to find a GL-5 synthetic available locally which is NOT designed for limited slip use but I'm having difficulties. I read things that say "designed for conventional or limited slip" or "good only to top off limited slip", thereby suggesting they are actually NOT good for limited slip? If it reads good for conventional differentials will that work?
Then I read a thread which suggested the Quicksilver High performance gear lube was ok but in reading over its specs, I can't find where it is compliant with GL-5 nor where it even says its synthetic.
How about the Sierra high performance synthetic blend lower gear unit oil?
I've got Mobilube 1 LS synthetic 75/90 in my outdrive now (have been running it for about 2 hours) which I realized today that its the wrong stuff.
Can someone recommend a synthetic gear oil which can be found locally - autozone, oriellys, advance, etc?
I can order the Volvo stuff on Ebay for $18 per bottle but I'd rather rely on local vendors if possible.
Thanks
Thanks
