Volvo Penta | Power Steering Hose Size
baker556
Hello all,
Last time I was with the boat I noticed ATF fluid leaking from one of the hoses connecting to the power steering pump, the hose in question is the one with the jubilee clip not the ones going to the RAMS (I assume).
I'm not with the boat and forgot to measure the width of the hose required (and I'm a good 6 hour round trip away) is anyone able to help me out getting the right size hose please.
Thanks
Volvo Penta has been using power steering for over 45 years and has had 7 different systems
Hello all,
Thanks
Ayuh,..... I'll Guess,........ 3/8" id,.....
baker556
@scott valid point, apologies I thought I'd added model year etc.
It's a 2003 VP 3.0 GSP-C
Thanks
should be 3/8" (10mm)
pressure line will be 1200 psi or higher line. best obtained from hydraulic shop and custom made
return line is 50 psi return line, available in bulk from any NAPA
baker556
It's jubilee clip so must be return line, thanks Scott - will get this on order.
Going to assume you are in the UK because the rest of the world calls them hose clamps
