Will2416ut
- Apr 27, 2016
- 1
Vovlo says that you cannot replace the motor on the assembly for the trim pump. I have taken off the pump /motor and water was getting in because it's rusted. Is this normal? Does anyone know if I can order an aftermarket motor to replace this locked up motor and install on top of pump? Cannot find part numbers as vovlo doesn't want you to replace just the parts - assembly kit is $880-1200!
