hckrphil
- Aug 8, 2004
- 162
Hi Everyone!
I have a 2000 Wellcraft Martinique 3000 cruiser I just bought this past fall. Long story short, needs some TLC. I removed the hydraulic rams (Volvo Penta SX-M) to rebuild the cylinders.
When removing 2 of them, the cylinder end (not the ram side) was severely corroded and very difficult to get off the pin that holds them on the boat. I literally had to use my 12 ton press to get them off! Anyways, not knowing any better, there were (2) metal bushings pressed into the aluminum hole that were VERY corroded.... so I hammered them out (and mangled the hell out of them in the process). I figured I'd remove them, then buy 2 more and press them in, no big deal right? Well, I don't think these metal inserts are for sale anywhere..... I can't afford to replace 2 cylinders at this point, and I'd hate to have to as these metal inserts were really just spacers.
Does anyone know where I can find these? I've attached a photo to better help describe what I am talking about.
Thanks a ton!!!!!
Phil
Thanks a ton!!!!!
Phil
