HELP NEEDED can't remove gimbal bearing. Tried slide hammer and puller, any suggestions
R roger100 Recruit Joined Nov 5, 2012 Messages 5 Nov 7, 2012 #1 HELP NEEDED can't remove gimbal bearing. Tried slide hammer and puller, any suggestions
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Nov 7, 2012 #2 Re: Volvo penta sxm gimbal bearing You need a big 10 lb. slide hammer for gimbal bearings the smaller 3 to 5 lb ones seldom work. If the bearing get cocked to the side, you may have to push it back in and try again and pull it out straight.
