Volvo Penta tilt problem
Pap_Pap
Hi everyone, I'm new here. I just bought a boat so I can my grandson fishing. Here's all the info I have on the boat. 1992 Future Craft 240 24ft. ENGINE: 431B/PS. Transom Assembly: Shield Engine 4101506591 / 104114011. Drive Unit: DP-C 872206. Now my problem. The outdrive is in the up position, I get no movement or sound when I move the Tilt Switch. I hear the hydraulic pump with the Trim down only, but nothing moves.
jerryjerry05
Clean the switch, WD-40 or any oil spray.
Then the connections at the pump.
Pap_Pap
Thanks for the reply. I cleaned both switches, checked them with ohm meter, says OK. Started raining will have to finish later. Question: That little oil pump that runs when I hit the trim switch, is that also the tilt pump?
Pap_Pap
Update so far: I cleaned both switches, checked them with ohm meter, says OK. Cleaned both relays and wire plugs. Nothing has changed. Pump only runs on trim down and nothing moves.
Pap_Pap
Fixed. Bypassed 1st set of relays. Now it goes from switch to pump relays, nothing else in between.
