fishingman52
- Apr 17, 2018
- 4
First time starting topic bare with me thanks in advance for all help have found much useful info here over the years and by no means claim I am a mechanic. 5.7 Vortec with 290 dp drive trim gauge. The problem started couple seasons ago and has gotten progressively worse. When problem started would just shut down motor and restart to solve problem now all the time. Trim gauge works just fine when key is at accessory position soon as key is turned to crank motor gauge goes haywire and gives different readings not consistent at all but still operates drive,gauge just doesn't read correctly if at all. So far this is what has been done replace trim sending unit and gauge, replace all 4 relays pertaining to trim system 2 on pump 2 at gauge replaced 70amp starter relay checked all grounds still problem not sure where to go from here help. By the way this is the round gauge not square
