Volvo penta trim pump circuit breaker
RJH1641
Hello everyone I am having an issue with tripping circuit breaker for the trim. I have twin 5.0 gi pefs with dp-sm drives. The problem is that the starboard breaker trips and the port loses power as well. I’ve been focusing on the starboard side replaced the breaker traced the wires I can see as it is tight in my engine bay. Pulled out the relays tested them and they checked out. The confusing part is why does the one breaker kill both trims when they each have there own separate breakers. Am I missing something here it’s becoming very frustrating any advice would be greatly appreciated
Bt Doctur
only if you have the system that raises both drives at the same tine but you have switches to lower each one separately
