VOLVO PENTA V8 300 C-A MISS POWER & BACKFIRE
Bob999333
Hi everybody,This model is equip whit catalyst system 1 sensor before catalyst and another after catalyst for each bank so 4 O2 sensor total.I replaced already the cap-rotor and wiring , good fuel pump and filter.I bought the Rinda Techmate pro and I have some code but the code don't match whit Volvo Penta code ????. I have detected 3 code : SPN=639 SPN=4238 SPN=3256 when I look in internet they all related to O2 sensor, I removed the 4 sensor and 2 look bad,is it possible this condition cause backfire and I cant go over 2000 RPM and no torque.I try to find the good shop manuel without sucess.Thank you in advance for your help.
muc
"Retired" Association of Marine Technicians...
I might be able to help, but an engine serial number makes it so much easier for me.
Bob999333
THANKS Muc, here the serial number I had ; engine parts: 40869423
serial; A223003
VPGAS035632 10/2012
2 TWC,H025,ECM,MFI
I really appreciate your help,have a great evening, Robert
Bt Doctur
639 12DTC 1627 CAN-J1939 Rx fault
4238 1DTC 1158Closed-loop gasoline bank2 low
3256 5 DTC 140 EGO3 open / lazy
Bob999333
Hey guys I found my problem, 2 spark plug was faulty on the same bank !!!! I replaced 1 month ago but I think I dont use the good one,
muc
Glad you found the problem.
If the Techmate will clear the misfire counter, I recommend that you do that after replacing the spark plugs.
