volvo penta v8 manifold freeze plugs
user-name
Does anybody know where I can new ones?
I removed old ones to clean out the MFs they were full of sand.
Factory one are SS. The volvo store is nuts 10$ a pop
alldodge
Measure them and then go to your local auto store and ask for brass ones. You can also find them on line but should be cheap. Inmost cases you can get an entire V8 worth for under 20 bucks
user-name
Thanks Brass will be plan B..... Plan A is to Tig weld the 3/16 hole that I drilled in them
user-name
No plan B brass wont work. Plan A failed beat them up to much. Now i'll just buy the $10.03 ones But volvo store is OOS
jerryjerry05
Hardware store ​1/2in pipe plug ask for brass.
Take old with you.
The older stuff Volvo used SAE and Merican works on them.
Ayuh,.... Why won't plan B work,..??
Core plugs are sold by material, 'n diameter,....
Goin' by the link ya posted, ya need 1, 3/8" core plugs, in either brass or ssteel,....
I believe the set AD linked are block core plugs, not manifold core plugs,...
Bein' 1, 5/8", yer right, those won't fit,...
Search somebody like dorman for 1, 3/8" brass/ ssteel core plug/ freeze plugs, 'n you'll find what ya need, cheaply, by the piece,...
For future reference, SoP to remove a core plug is to tap it in, in one spot to tip it, 'n then pull it out with pliers,....
Not that I'd reuse one anyways,.....
user-name
The plugs for the MFs are concave. so when you blast the center they flatten out and jam in to the MF. I cant find Brass concave plugs.
stand steel concaved are available.
