Thad
- Jun 8, 2009
- 1,028
I am putting a Michigan Wheel Vortex prop on my boat. It is a three piece prop and hub assy. Do I not use the thrust washer and the spacer washer that goes behind the nut? I assume this because neither one will fit with the prop.
Also, when the prop is on the shaft, if I put the nut on then the prop is able to move for and back apx. 1/4 inch. Is this proper or did I get sold the wrong prop?
Thanx guys.
Thanx guys.
