Volvo Prop Question
Jim Marshall
I have a 1974 Volvo/Ford 302 V8, Glastron, Volvo Outdrive. I have had it since new and have some prop questions.
I have only had one prop repaired in the years I have owned it. My spare prop has no numbers on it. It appears to be 14" diameter and has 17 splines.
I have also noticed that there seemed to have few options on props compared to Mercruiser.
Can someone enlighten me on the Volvo Prop situation? Are there high performance options?
Thanks,
Jim Marshall
Haut Medoc
Re: Volvo Prop Question
You might want to post this in the prop forum......;)
There are some members over there that are pros......:)
Don S
Moving to prop questions and topics forum.
f_inscreenname
Sure there is. You just not going to find through Volvo. About all of them are going to be aftermarket. Sadly I just changed internet providers and lost all my favorites (f_in MSN Explorer:mad:) but they are out there.
stevens
Well, it depends a bit on the type of Volvo outdrive. If you have the Aquamatic kind, prop choices will be much more limited than if you have the SX-type drive.
Here are a few links:
http://www.deltaprop.com/shopdisplaycategories.asp?id=449&cat=Sterndrives
http://www.volvopentastore.com/prop...vo+Penta&year=1974&rotation=Standard&x=23&y=9
http://www.boatsunlimitedny.com/volvo_prop.htm
You'll find many more using Google. The most important now is to determine your outdrive type and current pitch.
