hi my present prop is 3/18"long on inside hub edge toedge and 5" long on outside hub aera edge to edge. i can get a cheap replacement but it measures the same on inside hub area,but only 3 3/4"on outside edge to edge.will this work on my volvo 270 outdrive eng 125 aq.my props a volvo others a michigan wheel.do in need a spacer if so any i deal what they cost so i can tell what the total cost with prop will be. thank you in advance for the help .
