Volvo Spark Plugs
gapple12
I'm curious, on my Volvo Penta 5.0GL, can I just go to the local auto parts store and buy some nice double platinum spark plugs or do i need some sort of marine grade plugs ?
Georgesalmon
Re: Volvo Spark Plugs
no such thing as marine plugs as far as I know. Just get what is called for by Volvo for your engine.
skydiveD30571
You can use whatever plugs you want, but some words of advice:
1) Stay away from "Volvo Penta" or Champion plugs. They are the same thing, they are awful, you'll regret it.
2) For a carbed engine, Don always recommended ACDelco 41-993 which can be picked up at your local auto parts store or NAPA usually.
3) If the original ACDelco plugs are still in it, you can also take them to an auto parts store and cross-reference with NGK if you'd like.
4) Gap should be listed on the engine cover, but I believe the 5.0GL's were all .060.
skydiveD30571
Correct in that marine plugs don't exist. And even though following the Volvo manual is usually a great idea, this is one time you don't want to. Volvo Penta sells Champion plugs which are worthless. Stay away from those.
gapple12
Wow, glad I asked before I bought Volvo plugs. Thanks a bunch guys !!!
Ayuh,.... That's not quite True,....
for instance, For Chevy motors in boats, the pre-vortec heads use the AC Delco, MR43T spark plugs, or for the Vortec headed motors, the MR43LTS spark plugs,....
The automotive equivalents are the R43T, 'n the R43LTS,....
With the ACs, the M is Marine, 'n the plug bodies are an Alloy,....
Rather than just plain ole Steel as the automotive plugs are,...
As gapple12 does mention the vintage of his motor, either of those numbers maybe the spark plugs needed for that motor,...
Btw,.... "nice double platinum spark plugs", are a complete Waste of money,....
skydiveD30571
The OP has a GL-A motor, with a production year of 2001. I believe that is a Vortec engine but I may be entirely wrong.
If so, the MR43LTS or the 41-993 (platinum plug, not necessary on carbed engine but recommended on EFI engines) will do just fine.
Edit: Thanks for the correction Bondo, I never realized the difference :joyous:
SteveMcD
They make stainless steel spark plugs too. $10 each, but no more rust.
