This is my first post so thanks in advance to anyone who can help.My boat is a 93 crownline 250cr with a vp 5.7 dp.The three numbers i can find are.<br />572ps model???<br />4100145250 engine num????<br />868518 ???????? I got these from the cover on top of arrester. The drive not sure about as boat in water 280?? 290?? duo prop.<br />The problem i am having is when starting.I pump throttle 2/3 times and turn key the engine starts right away for 2/3 seconds then dies I can try this 8/9 times leave alone 1/2hour then try again this usally starts engine.Other times<br />doing same thing starts first time.The boat when running is fine except it will only rev to 3700 wot.I have changed plugs leads rotor and cap i did not see any points in dist also had drive serviced new seals bellows shift cable etc {1000 uk pounds
}The only thing i noticed was oil on top of carb i cleaned this of ran boat 5 hours<br />checked and oil was back is this being blown back from crankcase.The choke also seems to be working the compression test did gave me 7cyls 175/185psi. 1cyl 195psi.Idid this with throttle closed all plugs out should i have done it with throttle open and would it give different results<br />If anyone could give me some idea of what drive i may have i would be most grateful thanks again.
