iliketurtles
- Jun 25, 2011
- 15
Hi, I have a 1999 Monterey Montura 210 with a 5L Volvo and an SX outdrive. I have a factory stamped aluminum 17P prop. I bought a used 23P aluminium from a small repair shop as a spare. The 23P is not stamped Volvo but fits on the shaft. The problem is when you tighten the prop shaft nut it hits the housing pretty hard (the thrust washer is in place). The 17P hits the housing a little but works fine. I tried the 23 at just a little past hand tight and it made a terrible grinding noise - had to bring it back to the dock in reverse. So has anyone else ran into this? Do they make a shim / washer for cases like this? Thank you.
