Volvo sx to Mercruiser
Coldair
Volvo sx drive to mercruiser
First time posting I have a 95 Larson Hampton 200 that I picked up for CHEAP. Problem is the whole outdrive is burned up my question is what do I need to convert to a mercruiser outdrive from a volvo sx?
I'm not wanting to replace the transom.
bruceb58
Re: Volvo sx to Mercruiser
I would look for a used SX drive before I went through that whole mess. You realize you have to replace everything from the back of the motor aft right?
Ayuh,.... Welcome Aboard,.... Then yer gonna have to replace yer Volvo drive,...
Coldair
That's what I thought. I've been on the look out for an outdrive. What ones will work it came with a sx-m, gear ratio is 1.66
HorizonblueDK
Replacing a Volvo SX with a Mercruiser! Please don't, you will regret it every time you operate the gear/throttle handle and changing the impeller....
Unless you go for a Bravo drive.
