Volvo SX trim/tilt leaking hydraulic
VAeric
Boat Details: 97 Four Winns Sundowner 205 - 5.7GL Volvo - SX Outdrive
Usage: Chesapeake Bay
Towards the end of last season, I began to notice a light oil sheen behind my boat when moored for any length of time. When I pulled the boat out to winterize and inspect the tilt/trim hydraulics, I could see what appeared to be a metal ring around the ram which had pulled away from the cylinder (see pic). I tapped it back in place against the cylinder and wiped away some oil. Fast forward to today - as part of winterization, I placed a 55gal clear plastic bag over the entire outdrive to keep snow/water out. On the inside of the bag, I now have a pinkish, oily puddle. As I removed the bag, I could trace the oil back to where the ram moves in and out of the cylinder - the same cylinder I had tapped in the metal ring back in late fall. So, my questions are:
- Is replacing the seals on the trim/tilt cylinder (seal kit #3854247) a
job that requires pulling the outdrive completely off, or can I do one
side at a time with the drive still on the boat?
- Can anyone recommend a repair manual that has excellent detail (with
pics) to do the job?
- Any tips or tricks that would help, or "gotcha's" to avoid in doing a
job like this?
- Does saltwater cause premature failure on the seals if the boat is
kept in the water for 2-3 weeks before being pulled for a fresh water
bath in the driveway?
Thanks!
Don S
Re: Volvo SX trim/tilt leaking hydraulic
No, you don't have to pull the drive, just remove the trim cylinders. You will be able to lift the drive with the cylinders off.
Yea, it's called the OEM service manual. Best there is. See your Volvo dealer and ask for manual 7797367-5 or even check here at iboats at the link below.
http://www.volvopentastore.com/Genu...*****.958727904--store_id.366--view_id.366381
Do not get an aftermarket manual
