Glastron_V210
- Jan 28, 2009
- 324
Hi all. My port drive will not tilt.
I found the po removed the tilt motor, and removed the electical box and upper housing exposing the worm gear etc.
The issue is the gear is stripped from the motor drive to the tilt shaft. The motor input rotates freely with no action on the vertical shaft. I take it this is pretty common.
Additionally, the locking pin (Pawl?) is locked in. My dad figured it should release in forward gear, but no luck. I can jump in and try to release it...no biggie there. Should it come up easy by lifting after I release the locking pawl?
Thanks,
Chay
Thanks,
Chay
