Had to pump throtle to get boat to plane 23' and 165hp 6cl and could only get 22 mph out of it and top speed has been pushing 30mph. Started to over heat at higher speeds but would come down at lower speed ie.8-10 mph but still had to pump throtle.When got back to dock had oil in the bildge on both sides of the engine not in any particular place.The only area oil was present on engine was right by oil cooler but did have a little leak of air from the exhaust manifold not oil.Have tripple solex carbs and noticed the middle one on the intake matifold was a tan color and hot to the touch. Engine will still start and idle well with just a small surge in and out.Need a few ideas.No sludge in oil and very little vapor in carbs, plugs seem to be a little wet fouled and smell of gas,the fuel filter is clean.Just replaced themostate and repared water tube on stern drive but bought a impeller to put in. thanks
[is 30mph good for this boat and engine?]
