RebelCobalt
- Sep 27, 2010
- 14
I oringinally posted this problem in the prop section, but I'm beginning to think it's an engine issue, not something slipping between the engine and the prop. I have a 1998 Cobalt 220 with a 5.0Gi VolvoPenta throttle-body fuel injection engine and a VP duoprop outdrive.
To summarize, the engine turns on fine, idles fine, and revs fine in neutral. It goes in and out of gear fine, and moves forwards and backwards at idle (600 rpm) ok. When you give it some throttle, it accelerates ok (if a little sluggishly compared to normal), but tops out at about 15 mph and 2,500 rpm. If you give it some more gas, the engine gets louder, but the revs don't increase, and there's no additional thrust. It's almost like it's run out of power. If you keep pushing the throttle down, it eventually chokes, so it seems like it's getting enough fuel (ie I don't think it's the fuel pumps - the high pressure pump is only 2 years old).
The spark plugs weren't in bad shape, and all looked consistent (no carbon deposits), although some of them seemed hotter than others. We changed the fuel filter and spark plugs anyway, since they were cheap, and hadn't been changed in a couple of years anyway. But it didn't do anything.
We checked the props, coupler to the engine etc, and couldn't see anything wrong. So I don't think it's an issue of getting power to the outdrive. It's like a manual car going up hill in 4th - just doesn't seem to have the oomph it needs anymore. And it's happened all of a sudden. It was fine over Memorial weekend, but when the wife and I took it out last weekend, it started doing this.
Any ideas of other things to check? The air intake doesn't seem clogged. We're going to check the exhaust valve flaps tomorrow. I'm wondering if they got too hot, melted, and are blocking the exhaust gas (their flapping used to be a lot louder than it is now)? Do you think that would give us the symptoms we're experiencing? Any other ideas? This one is really puzzling...
