Can someone help me understand an issue Im having with cylinder head options.
My boat is listed as having a 97 5.7LX which has vortec cylinder heads. Last year I bought this boat with a blown engine. Removed the cylinder heads and they looked clean and in good shape with casting numbers 12558059, which I found out later on that they are 5.0 vortec heads. Original engine block was bad so I had to search and find a good block which wasn't easy even though Im in Houston.
I found a 2 bolt main 350 block with electric fuel pump it was from a 98 truck. I had the shop bored them .040 over, slapped the existing heads after machine shop checked them. But 2 hours of running and both side heads are either cracked or gaskets are toasted.
Did mercruiser 5.7's came with 5.0 heads in 1997 or did the engine I pulled out was a 5.0?
I will be removing the heads tomorrow morning and I was wondering if I should order 5.0 or 5.7 heads? Ebay has brand new 5.7s for a fairly low price.
Any info or help is appreciated as I don't want to go through this one more time.
