Re: Vortex prop
I used a Vortex 13 X 19 aluminum prop. It loaded the engine down a couple of hundred RPM less than the stock prop and as I remember, the top speed was either about the same or very slightly less than with the stock prop.
It is a very well finished prop but: Since I don't like aluminum props and I am all about speed, I sold another engine with the Vortex on it.
The webs inside the hub extend well into the rear of the prop hub and cause interference.so if you want to use the prop on your 1988, you will either need to mill the webs for clearance OR remove the anode. Later model Force engines used an anode without the very high walls so if you buy one of these, the prop will also fit.
There is supposed to be a special thrust washer for the Vortex but you can use the stock thrust washer.
