Vovlvo fresh water cooling
sty2112
I used to run fresh water cooled crusaders that early season would bind up with mussels/clams in a hose. In particular, the hose from the raw water pump to the tranny oil cooler. The hose had 2 quick bends. Where, if so, does this happen in the volvo fresh water cooling system? Raw water part of it that is... Any seasonal service recommended for the vertical mounted heat exchanger?
jerryjerry05
Re: Vovlvo fresh water cooling
Model,serial# any other info.That way we know what were woring on.A few pics would help.J
sty2112
Sorry failed to mention that. Small block 350 (290 AQ Drive) with the vertical style heat exchanger pictured below.
