hey...hope someone can help
V8 Volvo Penta early Model. Engine runs fine, but when revs reach about 2000 rpms, water begins to come out the over flow tube on top the the heat exchanger. If I back off the throttle, water stops coming out of the overflow tube. Water in heater exchanger does not get very hot...can easily touch when I remove the cap. According to new temperature gauge, motor temp is not getting above 100-110 degrees. I suspect blockage somewhere but do not know enough about coolant flow.
Motor can be viewed here:
Library Slideshow by sat1425 | Photobucket
thanks for any advice.
