VP 290 can't get bolt out of metal ring over the rubber ring.
old bird
I think it's a 290 drive, it was installed in 1987 or 89 with a 5.7 in an old 68 Chris Craft. The other 5 bolts came loose, but 1 is not budging.
Any suggestion. What would you try.
Thanks
PatinIdaho
The clamp ring holding the two large rubber o rings to the transom shield?
If so the best way is to remove the engine from the flywheel cover. Once the engine is out you can then heat the bolt boss on the inside of the flywheel cover with MAP GAS ONLY to get the last bolt out.
Thanks
Put the 5 bolts back in, tighten them up, then loosen the 6th. Your supposed to back all bolts off evely, or the last bolt us under so much tension it wont turn from the force of the donut
One you have all 6 bolts out, put 3 into the tapped holes to drive the ring off
old bird
Wow, Thanks Scott. I'll put the other bolts back in and go that route.
I'll let you know.
old bird
That didn't work. I put the bolts back in, tightened to 30 lbs., how tight should I torq them ?
Rounded the head. Now its cut or drill the head off. How do I get the bolts out so I can remove the helmit from the steering arm to give me another 1/2 " of work space.
loosten the steering tiller arm clamp inside the boat and the whole helmet fork and helmet will drop out
old bird
Got the helmet off. Grinded the head off the bolt. Cleaned out the 3 tapped holes and stuck a bolt down, but it doesn't seem threaded ??
That's enough for today, I'll hit it again tomorrow.
kenny nunez
If every thing you have tried does not work. You will have to get an air chisel and work it about 3/4" from the outer edge of the ring and break enough of the ring to pull the engine out. Then use the air chisel to break it apart to remove the frozen bolt. I have had to do it this way a few times, you just have to sacrifice the ring.
the threaded holes are helicoiled, so worse case, you need to get a new helicoil.
old bird
Thanks You'll,
I got the ring out. Now I have to build a ganrty, pull the engine, work on the bilge, get another engine, install the drive, etc. and go fishing and cut the grass, busy busy !!
